Error nueva version
http://ea6dd.com/foro/viewtopic.php?f=9&t=39
Autor:  EC7AT [ Lun May 04, 2009 10:35 am ]
Asunto:  Error nueva version
Application
Path and name: C:\Archivos de programa\EA6DDlog\EA6DDlog.Exe (32 bits)
Time from start: 0 hours 0 mins 1 secs
Error occurred at: 04-05-09, 12:32:57
Error description: (DOS Error 2) DBFCDX/1001 Error de apertura: Log.dbf
Stack Calls
Called from: => DBUSEAREA(0)
Called from: Source\Network.prg => NETUSE(32)
Called from: Source\Utiles.prg => ACTVER(719)
Called from: Source\Utiles.prg => (b)SETUP(511)
Called from: .\source\function\MSGRUN.PRG => (b)MSGRUN(36)
Called from: .\source\function\MSGRUN.PRG => MSGRUN(42)
Called from: Source\Utiles.prg => SETUP(511)
Called from: Source\EA6DDlog.prg => (b)MAIN(159)
Called from: .\source\classes\WINDOW.PRG => TMDIFRAME:PAINT(2353)
Called from: => TMDIFRAME:HANDLEEVENT(0)
Called from: .\source\classes\WINDOW.PRG => _FWH(3333)
Called from: => UPDATEWINDOW(0)
Called from: .\source\classes\WINDOW.PRG => TMDIFRAME:ACTIVATE(936)
Called from: Source\EA6DDlog.prg => MAIN(162)
System
CPU type: Intel(R) Pentium(R) 4 CPU 2.80GHz 2817 Mhz
Hardware memory: 1024 megs
Free System resources: 90 %
GDI resources: 90 %
User resources: 90 %
Compiler version: Harbour 1.1.0dev (Rev. 10434)
Windows version: 5.1, Build 2600 Service Pack 3
Windows total applications running: 41
1 M
2 Default IME
3 Menú Inicio
4 CiceroUIWndFrame
5 Descargas activas
6 TF_FloatingLangBar_WndTitle
7 ALSMTray
8 CL RC Engine3 Dummy Winidow
9 Actualizando base de datos
10 EA6DD Win Log 0.7.2
11 Connect: Hy-Gain DCU-1
12 Output
13 HamRadioDeluxe - [Logbook Entries]
14 Creando documento Adobe PDF
15 AcrobatTrayIcon
16 XTPTopLevelWndMsgNotifier
17 Help
18 Pleas, wait...
19 IconRestorer
20 {A7E495BF-9589-4a6e-8479-DDA2D8D3C05F}
21 PCSuite
22 SerLa
23 MCI command handling window
24 Nokia PC Suite
25 _XpDeviceWatchDog
26 Free Download Manager
27 DDE Server Window
28 4ec
29 QTPlayer Tray Icon
30 CDirectoryChangeWatcherHelperWindow
31 avast! UI Control Window
32 avast! Antivirus
33 OdiOlDVR
34 Device Detector
35 CtHelper32
36 Connections Tray
37 Medidor de energía
38 MS_WebcheckMonitor
39 aswServ helper window
40 BTTrayMainWindow
41 Program Manager
Variables in use
Procedure Type Value
DBUSEAREA
Param 1: O Class: ERROR
NETUSE
Param 1: L .T.
Param 2: C "DBFCDX"
Param 3: C "Log"
Param 4: C "Log"
Param 5: L .F.
Param 6: L .F.
Local 1: U
Local 2: N 0
ACTVER
Param 1: C "Log"
Param 2: L .F.
Param 3: N 1
Param 4: C "Log"
Local 1: C "DBFCDX"
Local 2: L .F.
Local 3: L .F.
Local 4: L .T.
Local 5: N 1
(b)SETUP
Local 1: U
(b)MSGRUN
Param 1: O Class: TDIALOG
(b)TDIALOG
Param 1: U
TDIALOG:DISPLAY
TDIALOG:HANDLEEVENT
DIALOGBOXINDIRECT
Param 1: N 15
Param 2: N 0
Param 3: N 0
TDIALOG:ACTIVATE
Param 1: N 4194304
Param 2: C "€ w  A c t u a l i z a n d o b a s e d e d a t o s "
Param 3: N 0
Param 4: O Class: TDIALOG
MSGRUN
Param 1: U
Param 2: U
Param 3: B {|| ... }
Param 4: L .T.
Param 5: U
Param 6: L .T.
Param 7: U
Param 8: U
Param 9: U
Param 10: L .F.
Local 1: N 0
Local 2: S
Local 3: O Class: TDIALOG
SETUP
Param 1: C "Espere por favor ..."
Param 2: C "Actualizando base de datos"
Local 1: O Class: TDIALOG
Local 2: N 237
(b)MAIN
Local 2: U
Local 3: O Class: TBRUSH
Local 4: U
TMDIFRAME:PAINT
Param 1: N 1661016051
Param 2: C "lB İý¬è¸¹ ŽU€¿
0±ý§¿¬è¸¹"
Param 3: O Class: TMDIFRAME
Local 1: A Len: 5
Local 2: N 0
_FWH
Param 1: N 15
Param 2: N 0
Param 3: N 0
UPDATEWINDOW
Param 1: N 0
Param 2: N 15
Param 3: N 0
Param 4: N 0
Param 5: N 1
Local 1: O Class: TMDIFRAME
TMDIFRAME:ACTIVATE
Param 1: N 2687868
MAIN
Param 1: C "MAXIMIZED"
Param 2: U
Param 3: U
Param 4: U
Param 5: U
Param 6: B {|| ... }
Param 7: U
Param 8: U
Param 9: U
Param 10: U
Param 11: U
Param 12: U
Param 13: U
Param 14: U
Param 15: U
Param 16: U
Param 17: B {|| ... }
Param 18: U
Param 19: U
Local 2: U
Local 3: U
Linked RDDs
DBF
DBFFPT
DBFNTX
DBFBLOB
DBFCDX
DataBases in use
1: FRMQSL RddName: DBFCDX
RecNo RecCount BOF EOF
1 3 .F. .F.
Indexes in use TagName
Relations in use
2: LIBROS RddName: DBFCDX
4 4 .F. .F.
Relations in use
Classes in use:
1 ERROR
2 HBCLASS
3 HBOBJECT
4 TAPPL
5 TINTERNET
6 TFTP
7 TSTRUCT
8 TWINDOW
9 TCONTROL
10 TICON
11 TBRUSH
12 TMDIFRAME
13 TMENU
14 TMENUITEM
15 TMDICLIENT
16 TFONT
17 TMSGBAR
18 TRECT
19 TMSGITEM
20 TTIMER
21 TBITMAP
22 TREBAR
23 TIMAGELIST
24 TTOOLBAR
25 TDIALOG
26 TREG32
Memory Analysis
358 Static variables
Dynamic memory consume:
Actual Value: 709862 bytes
Highest Value: 710232 bytes
Autor:  EA6DD [ Lun May 04, 2009 8:38 pm ]
Asunto:  Re: Error nueva version
Es estaño, parece como si no hubiera ningún log definido. En cualquier caso he realizado un cambio en el proceso de actualización, creo que ahora no te dará error.
